Originally Posted by
tom.marg
cheers Tim, I’ve got the passenger side back side tacked on, and the front braket marked out. Cut it out and drill the hole in the right place and they can be tacked on. Then address some gusseting for strength a bit like you’d see on a strutted front tube car. Once that’s done some fake rod shocks can go in and technically the car could roll. I will be leaving it in the air through ease of working at the height it’s at, once they are in a bit of a clear up I think then the next stages will most likely be seating , steering and brake pedal position.
